Great questions! Integrating OpenTelemetry-based distributed tracing into Argo Workflows is a solid approach to gain deep visibility into workflow execution and latency bottlenecks beyond metrics and logs.
Here’s a detailed breakdown addressing your points:
Components to integrate Argo Workflows with OpenTelemetry:
Instrumentation libraries: Your workflow steps (containers or scripts) need to emit OpenTelemetry spans. This requires adding OpenTelemetry SDKs to your code or wrapping existing commands.
OpenTelemetry Collector: Deploy an OpenTelemetry Collector in your cluster. It receives trace data from instrumented steps and exports it to a backend like Jaeger or Tempo.
Tracing backend: A system like Jaeger, Tempo, or Zipkin to store and visualize traces.
Argo Workflow controller config: Optionally, configure the Argo Workflow controller to propagate trace context across steps. This can be done by injecting trace headers as environment variables or annotations.
Collecting Span information per workflow step:
Code changes: If your steps run custom code (Python, Go, Java, etc.), add OpenTelemetry SDK instrumentation to create spans around logical operations.
Sidecar or init containers: If you cannot modify the code, consider running an OpenTelemetry sidecar or using automatic instrumentation agents.
Annotations or environment variables: Pass trace context to each step via annotations or environment variables to maintain trace continuity. Argo supports workflow-level metadata injection; you can extend this for tracing headers.
Custom templates: Modify your workflow templates to include OpenTelemetry environment variables or commands that start tracing.
Tracing backend recommendations:
Jaeger: Widely used, mature, and integrates well with Kubernetes and OpenTelemetry Collector. Good UI for trace visualization and analysis.
Tempo (Grafana Tempo): Highly scalable, cost-effective, and integrates seamlessly with Grafana dashboards. It’s optimized for storing large volumes of trace data with minimal operational overhead.
Zipkin: Simpler but less feature-rich than Jaeger or Tempo. Practical advice from experience:
Start with Jaeger for ease of setup and community support.
Use OpenTelemetry Collector with the Jaeger exporter to centralize trace ingestion.
Ensure trace context propagation across workflow steps by injecting traceparent headers as environment variables.
Combine tracing data with your existing Prometheus/Grafana metrics for full observability.
Monitor the overhead of instrumentation and sampling rates to balance data granularity and performance.
If you want, I can help you with example Argo Workflow templates or OpenTelemetry Collector configurations tailored to your environment. Just let me know!
